Gear oil question
Gear oil question
I'm having my 4.10s installed this weekend and was wondering about gear oil. The factory weight recommended is 80w-90. I wanted to use Royal Purple, but they don't make 80w-90, but they do make a 75w-90. Now I've heard that youcannot us the 75w-90 with the 8.8 LSD, but I also heard that youcan use it. So I'm alittle confused. One guy says you cannot use it because it messes with the LSD diffs, I called another performance turning shop and the guy said they use 75w-90 all the time. Any help clearing this up would be great. Also I'm aware of the Ford additive needed for the limited slip. Thanks as always for the help!
RE: Gear oil question
I've used 85-140 w/ great success.. Don't forget Friction Modifier.. Although w/ a good synthetic, you may not need the modifier...
Also note, although it shouldn't have made a difference, that I had an Eaton Center section....
JT
JT
ORIGINAL: sprostang
Yeah, if you use royal purple, you don`t need the modifier.
musnicki
09-23-2015 07:11 AM
09-03-2015 07:14 PM
