shifting fork!!!
Old Feb 19, 2007 | 11:30 AM
dgantt's Avatar
dgantt
Default shifting fork!!!
Anyone, what are the symptoms of a bent shifting fork. Thanks
Old Feb 19, 2007 | 07:12 PM
bryanec's Avatar
bryanec
Default RE: shifting fork!!!
Shifter usually jumps out of gear.
[align=left] [/align]
Old Feb 19, 2007 | 07:20 PM
dgantt's Avatar
dgantt
Thanks, after further invesigation I found out my car has an aftermarket short shifter with stop bolts. As long as they are set correct I should not have a bent shifting fork issue. I hope anyway.
Old Feb 19, 2007 | 07:35 PM
djb1187's Avatar
djb1187
nah i had a steeda tri-ax and i still bent my shift fork
Old Feb 19, 2007 | 07:46 PM
dgantt's Avatar
dgantt
I installed that steeda clutch kit this weekend and it did not solve my problem. I ordered a spec stage 2 clutch today, I hope that does it, what did your car do when you bent that shifting fork?
Old Feb 19, 2007 | 07:47 PM
djb1187's Avatar
djb1187
it wouldnt go into 4th gear. it would just pop right out as soon as i let off the clutch.
Old Feb 19, 2007 | 07:52 PM
dgantt's Avatar
dgantt
Well I have not made it that far, after I installed the steeda clutch kit and it was still making noise I left it set. By the by when your shifting folk was bent did your clutch make noise. I'm just trying to rule out a bent shift fork since I was power shifting when all this happened. Thanks
Old Feb 19, 2007 | 07:58 PM
djb1187's Avatar
djb1187
nah. my clutch was silent. shift fork is inside the trans and has nothing to do with your situation. do you mean clutch fork?
Old Feb 19, 2007 | 08:00 PM
dgantt's Avatar
dgantt
Sorry, yes clutch fork.
Thunderball
15
Nov 22, 2015 11:49 PM
UrS4
Oct 3, 2015 06:23 AM
Explosive
Oct 2, 2015 07:45 AM
ccdguy
Sep 19, 2015 05:20 PM
Mustangmalo
Sep 6, 2015 05:22 PM
