Eibach sawy bars-has anyone used them?
I am doing MILD suspension upgrages.
KYB GR-2 shocks/struts, 1.2" Ford Racing/Eibach progressive rate springs, solid steering rack bushings. I can get a good deal on Eibach sway bars, $233. shipped to me after a $20. rebate. 24mm solid rear and 36mm tubular front bar. Doesn't seem as though anyone has tried them as I have not found one! Anyone? Thanks
RE: Eibach sawy bars-has anyone used them?
So you you think they are worth the $233. to my door? "alot better in the corners" is what I am looking for and since I am replacing the rear springs/shocks I need to remove the rear bar anyways.
Is the stock rear tubular and the Eibachs reversed with the front tubular and the rear solid? I have another unrelated question so if you want to answer in a PM I will get back to you in a bit. Thanks, mark
