Gain 8HP to the WHEELS! easy!
#31
RE: Gain 8HP to the WHEELS! easy!
ORIGINAL: jmat2407
Really? A camero? Come on the first one came out 40 years ago I think we should be able to spell it by now...camAro
ORIGINAL: badboystangGT
I was watchinghorse power TV this morning and they took a stock camero and base lined it, i forgot the exact numbers then they changed all the oils the engine the tranny and the diff to royal purple and they gained 8HP TO THE WHEELS! then they showed how they made this stuff and its so complicated it goes through so many tests through the lab before they even start producing it then they couldnt show the viewers exactly how the process was that it was made and what was in it thats how secert they are about the procees and the forumla
#32
royal purple is, for whatever reason mechanically, from everything i've seen, a fantastic product. i've seen tons of stuff that shows improvements. its just better oil. will you see 8 RWHP gain from swapping out engine, tranny, and diff fluid? probably not. but you have nothing to lose; the engine runs more efficiently, less drag on the engine, which can only mean better MPG, less engine wear, and more free HP either way.
#33
ORIGINAL: jmat2407
#34
I had used Mobil 1 for the previous three oil changes before trying out RP for my most recent change. I can't guarantee an 8 hp gain, but I did notice a significant difference in pick-up and acceleration. It also seems to run smoother than after previous oil changes.
#35
ORIGINAL: tool fan
(not that I have this issue) A well renowed mech told me that up past 420 HP synthetic is garbage and to stick with regular oil at those ratings..... I don't have those ratings so I use Mobil 1
Horsepower levels have nothing to do with it. Better lubrication is better lubrication. Synthetic oils reduce friction significantly (if you don't believe it, try the hold a screwdriver dipped in it test) and are better able to take the abuse of high heat situations.
Synthetic FTW!
#36
Those guys are a couple of shills. I saw one show where they were pushing the Terminator, they were gushing about how it adds HP. You knowwhat I'm talking about, that metal fan shaped piece of crap you put in your air intake. Anything for a buck.
That one douchebag needs to get a better rug on his head too,I can spot that birds nest a block away.
mungodrums
09-28-2015 10:54 PM
