overdrive
Old Feb 26, 2007 | 12:32 AM
D281's Avatar
D281
Default overdrive
whats the difference if the overdrive is on or off. i heard it has to do with torque and at higher speeds it goes faster. any comments?
Old Feb 26, 2007 | 12:33 AM
blownstangboosti's Avatar
blownstangboosti
Default RE: overdrive
overdrive is like an extra gear to keep the revs down
Old Feb 26, 2007 | 02:41 AM
D281's Avatar
D281
so is it the same power at lower rpms, thus making more power in a gear.
Old Feb 26, 2007 | 02:44 AM
ZW99GT's Avatar
ZW99GT
? turning it off just STOPS it from going into overdrive. Nothing more that I know of. Its gonna do the same thing. 1-2-3-OD. If its off, it will go 1-2-3.
Old Feb 26, 2007 | 09:13 PM
D281's Avatar
D281
so does either one have a power difference. if so which gives the most
Old Feb 27, 2007 | 01:49 AM
03GTGreen's Avatar
03GTGreen
As far as I can tell... whenthe overdrive is off it takes longer to shift to the next gear. Like in mine, were it usually would shift into 4th, itll stay in 3rd. As far as having more power, pry not, however, if you were doin a roll and then gunned it at 70 it would pry only shift down to 3rd, where as if you had the O/D off it would go to 2nd.Thats how it is in mine, couldnt tell ya about the other guys.
Old Feb 27, 2007 | 07:13 PM
Jakes's Avatar
Jakes
ORIGINAL: D281
There is no difference in "power". OD is just another gear. 1-2-3-OD. It allows the engine to turn at lower revs when cruising down the higway.
CarrieS
Sep 1, 2015 01:00 PM
erig94gt
Jun 11, 2005 03:14 AM
BlackGT5.0
Feb 15, 2005 01:05 AM
89stanglx
Feb 3, 2005 11:17 PM
88_5.0
Dec 24, 2004 04:17 AM
