Stage 2 cams
Old 02-26-2007, 05:25 AM
96_LAstang
96_LAstang's Avatar
Default Stage 2 cams
Ok, I'm about to do a PI swap in about a month and i want to go with stage2 cams. I am going to buy bare heads, and need to know the best place to get the valve springs and stuff for the stage 2 cams?
I've been considering this: http://www.americanmuscle.com/patrio...t-9904-2v.html
96_LAstang is offline
Old 02-26-2007, 06:42 AM
2000GT4.6
2000GT4.6's Avatar
Default RE: Stage 2 cams
If your going to upgrade the springs comp beehives FTW.
Are you sure you won't have PTV clearance issues with a NPI motor that has a PI swap and the stage 2s?
2000GT4.6 is offline
Old 02-26-2007, 08:28 AM
97tplsGT
97tplsGT's Avatar
PTV=????? sorry for ignorance, just better to know then wonder........
97tplsGT is offline
Old 02-26-2007, 11:09 AM
Davojan59
Davojan59's Avatar
piston to valve clearance
Davojan59 is offline
Old 02-26-2007, 11:57 AM
redstanger
redstanger's Avatar
back in the day i bought mine on ebay. cheaper there than anyother place by around 10-20bucks
redstanger is offline
Old 02-26-2007, 07:57 PM
96_LAstang
96_LAstang's Avatar
Honestly havent even thought about it, i not sure if i will. I just want a really agressive lope. Anyone know if i will have PTV problems with the stage 2 cams with a npi motor with pi swap?
ORIGINAL: 2000GT4.6
Old 02-26-2007, 07:59 PM
phalcrow
phalcrow's Avatar
You will FOR SURE have PTV problems if you do not get the pistons fly cut OR degree the cams. I did the exact same thing and screwed up all my pistons.
phalcrow is offline
Old 02-26-2007, 08:05 PM
96_LAstang
96_LAstang's Avatar
Thanks, but what exactly is done to degree cams?
ORIGINAL: phalcrow
Old 02-26-2007, 09:15 PM
phalcrow
phalcrow's Avatar
Not sure, I ended up getting a new shortblock built with fly cut pistons. I know to degree them you need to use a degreeing wheel and a lot of patience. It seemed like too much of a pain in the a$$, plus, I needed new pistons anyway, so I just paid the extra $200 to have the valve reliefs machined in. Somebody else should chime in and give a link on how to degree cams. hint, hint.
phalcrow is offline
Old 02-26-2007, 10:09 PM
96_LAstang
96_LAstang's Avatar
Im probably going to settle for the stage 1's, to save myself some trouble/money, until i can do a complete rebuild
jwog666
12-27-2021 08:09 PM
patchshaffer
Tuner Central
10-05-2015 02:24 PM
uedlose
The Racers Bench
10-01-2015 08:31 PM
junior04
09-28-2015 10:53 AM
09-25-2015 09:06 AM
Quick Reply: Stage 2 cams
