VT stage 2 HELP!!!!
VT stage 2 HELP!!!!
Sorry to post about cams for the hundreth time, but I am getting ready to order the VT stage 2's and I was wondering if I will have any PTV clearance issues? Please let me know.
RE: VT stage 2 HELP!!!!
i have vt stage 3 cams and had no problems with ptv.... also.... i ran for 3 months without aftermarket valve springs all the way to red line (6500rpms) without problems....
I am running the stage 2s, you should not have PTV so long as you degree the cams correctly.
Make sure you spin the engine by hand and check for PTV before starting, this is a good policy after any cam install. Anything can go wrong, so make sure you check it, but if you do the job correctly everything will be fine.
jwog666
12-27-2021 08:09 PM
junior04
09-28-2015 10:53 AM
09-25-2015 09:06 AM
