Transmission question
Old Nov 3, 2004 | 08:54 PM
Casper98GT's Avatar
Casper98GT
I ♥ Acer
Default Transmission question
I put in my king cobra clutch kit about 5-6 months ago. I enjoy it... but the throwout bearing HAS to go... im pretty sure its already on its way out. My problem is, i beat the trans pretty good, with shifting. Well, now when i have my foot OFF the clutch, it squeeks, like it usually does. Well now when i push in the clutch pedal it makes a horrific noise. Maybe i bent the shift fork, maybe the throwout bearing is just almost ready to say good night. Anything would help. I've tried playing around with my adjustable cable to see if the noise would go away, i've had it all the way to the top and at the bottom to engauge, but nothing changes it. So, what kind of throw out bearing does well. I need somethign heavy duty. I might even go ahead and put a whole new clutch in.
Old Nov 3, 2004 | 09:01 PM
Dan04COBRA's Avatar
Dan04COBRA
Default RE: Transmission question
Sounds like it's just your throw-out bearing.
There isn't much you can really do, if it's on it's way out...well you know the drill. Get to work
Old Nov 3, 2004 | 10:01 PM
Casper98GT's Avatar
Casper98GT
I ♥ Acer
Yeah, im ripping it out next weekend. It takes me about 3 hours to remove, replace clutch, flywheel and replace. So its not a big deal . I was just wondering if there is a better throw out bearing.
Old Nov 4, 2004 | 12:31 AM
jzkstang's Avatar
jzkstang
Are you using a hoist when you take your trans out or are you on the floor? It took me all day on the floor. if you have any secrets that would be great.
Old Nov 4, 2004 | 01:39 AM
97stangv6's Avatar
97stangv6
ORIGINAL: Casper98GT
Three hours to change a clutch??
I would like to know what tools/equipment you are using that you get it done so fast!
About the bearing, i havent heard of anything better then OEM. Maybe the cable was to tight? Because i beat on my 6er everyday and i havent had any probs with my new clutch or bearings and its been in their for about as long as yours.
Old Nov 4, 2004 | 06:25 PM
USAMuscle's Avatar
USAMuscle
Well technically anytime you replace your clutch you should also replace the throwout bearing. Too late for that though...lol. Anyway just go to your local auto parts store and get a self-aligning throwout bearing for about $35. That's what it cost me.
Old Nov 4, 2004 | 07:57 PM
Casper98GT's Avatar
Casper98GT
I ♥ Acer
To answer youre questions about the 3 hours. Im a ford tech and i do it all the time. Once you do it a couple of times, its pretty easy. I do use a lift at my dealership. I did replace my throw out bearing when i put the new clutch in. But i was wondering if there are any heavy duty tob's out there.
Old Nov 4, 2004 | 10:18 PM
USAMuscle's Avatar
USAMuscle
I've never heard of any heavy duty throwout bearings. It's a pretty general part with a very simple purpose, so probably what you get at the auto parts store is about the same as what you'd get anywhere else. Some clutch companies like RAM sell their own brand throwout bearings, but I'm not sure if they are really any better than the others.
AmericanMuscle4.6GT
Nov 10, 2015 02:06 PM
04stangman
Sep 17, 2015 01:45 PM
LivingInThePast
Sep 16, 2015 12:20 PM
vintageaion
Sep 8, 2015 10:45 AM
