high impact axles
my car is pushing out enough hp's now that i need to start worrying about blowing out the rear end. i have no idea when it comes to axles on what size or how many splines and what not that i would need. would anyone be able to help me out with what i would be looking for for my 04 gt? I'm eventually looking to put out a lot of power with this car and want to change these axles once. any help would be great.
You'll need 31 spline axles and a 31 spline differential. Below are links to what you need basically
http://www.americanmuscle.com/moser-...axle-9904.html
http://www.americanmuscle.com/eaton-...-posi-lsd.html
ORIGINAL: bizarre660
wow thats def expensive for that posi. is that the best application? cause if im gonna spend that much on a rear i want to only change it once. ya know
You could also look for a 31 spline 8.8 Ford truck differential (100 bucks or so) and have it cleaned up. Then you could get your 31 spline axles. It'll save you a good chunk of change. Several of our locals here do that and they're still holding up after 100's of 5-6k launches on d/r's and slicks alike.
What kind of power levels are you making, and what tires are you running? So long as you run nothing more sticky than a nitto d/r you should have no problems with the stock 8.8
KingRando
Oct 2, 2015 08:06 AM
Sep 24, 2015 09:18 PM
