i have a problem with overheating
ok i no this is a mustang thread but this is actually for my daily driver which happens to be a oldsmobile alero 01 i no ppl might say go to a gm site but hey i think all over heating symptoms might be the same.
ok so here is the thing in traffic and in town the car starts to over het justa lil but in the freeway or anywhere where im just gas all the way its perfectly ok. i no there might be like 5 things it can be but what do u guys think and from experience what is it. thanks
RE: i have a problem with overheating
ORIGINAL: sleeping stallion
yea i have enought coolant and last time i check my fan was working would the thermo stat haveanything to do with it
NO NO NO.... All of these replies and no one points out or realizes you have a GM which are notorious for bad waterpumps! They are expensive and really hard to change if you have the 4 cylinder! The 6cylinders aren' that bad. I would say it's most likely your waterpump. Are you losing any coolant? Do you see any fluids under the car, because the seals tend to let go when the bearings do and will dribble coolant outta the **** hole! Maybe not with the newer ones, but I def. Think you have a waterpump prob. I would change your thermostat which I think you have to change the whole housing (lovely GM design) and then if not I would reccomend a new pump!
mungodrums
09-29-2015 09:18 PM
stangin1996gt
09-21-2015 11:01 AM
yourmom6990
09-14-2015 10:52 PM
