Who has used RP synchromax??
Old Mar 29, 2007 | 03:24 PM
NeedStangSpeed's Avatar
NeedStangSpeed
Default RE: Who has used RP synchromax??
how does a tranny with no pump create too much pressure? like the 3650? Just wondering not sharpshooting are anything.
Old Mar 29, 2007 | 04:40 PM
cliffyk's Avatar
cliffyk
TECH SAVANT
You would have to significantly overfill it (like stuffed full) to damage something from pressure buildup, however the oil level does affect shifting as it can hydraulically restrict the motion of the shift rods and their detents, the forks, and other sliding components--I suspect that the reduced fill amount recommended by Ford and Tremec permits these components to move more freely...
Old Mar 29, 2007 | 05:31 PM
Donnie's GTS's Avatar
Donnie's GTS
ORIGINAL: NeedStangSpeed
things expand when the heat up, thats why.
Old Mar 29, 2007 | 08:01 PM
sprostang's Avatar
sprostang
I ♥ Acer
Well I just picked up 3 qts at NAPA on my way home. According to them it takes 2.83 qts. My manual says the same. So it looks like 3 qts will be enough. (Hopefully)
Old Mar 29, 2007 | 08:16 PM
cliffyk's Avatar
cliffyk
TECH SAVANT
I would recheck that spec, the 2004 Owner's Manual I have says 7.8 pts. (3.9 qts.; page 217)--the V6 tranny is spec'd for 5.6 pts.which is 2.8 qts.[/align][/align]
Old Mar 29, 2007 | 08:41 PM
Azure's Avatar
Azure
3.27qts is what has always been quoted me for my T45, and that's what I put in it when I put in my MGW and changed the fluid to Synchromax 2 months ago. There's been a pretty noticeable improvement, and it definitely cleaned up the occasional grinds.
Old Mar 29, 2007 | 08:47 PM
sprostang's Avatar
sprostang
I ♥ Acer
Yeah I just checked and 3 qts wont be enough. I should of checked before I went and bought the stuff. Shows you how much these parts guys know. Now I have to go back for anotherqt. [&:]
yourmom6990
3.7L V6 Technical Discussions
Oct 14, 2015 10:08 PM
stags
Feb 13, 2012 05:10 PM
stags
Jul 4, 2011 01:02 AM
moosestang
May 12, 2008 11:22 AM
Lbzmotofmx
Sep 12, 2007 02:21 PM
