what oil to run in my gt?
Old 04-07-2007, 12:59 PM
undecided.steve
undecided.steve's Avatar
Default RE: what oil to run in my gt?
ORIGINAL: 00TropicGreenStang
ORIGINAL: handyandy
Just run whats recommended for it on the oil cap. 5W-20 (or is it 5w-30?)
I have a 2000 and it says 5w-20 on my cap. I think the 96-99 said 5w-30? My friend said he knows a guy with a '99 and it's different.
Anyway, I use Mobil 1 full synthetic but I heard it wasn't actually full synthetic... idk someone posted on here saying that. I am going to try Royal Purple next time. I had my motor apart for almost 2 months so I will treat it to some Royal Purple.
Read all about oil, filters and stufff like that here.
http://theoildrop.server101.com/foru...eads.php?Cat=0
I'm currently using Mobil 1 "Full" Synthetic, but next change I am going to switch to the new Penzoil Synthetic which is getting excellent reviews on various sites.
From what I understand Penzoil is up front about what's in their oil where Mobil 1 is a little more clandestine.
I use a Mobil 1 or Motorcraft filter.
K&N is also a good filter as is Wix.
Fram filters suck with the exception of the X2 model which is good but way over priced.
One thing about the Motorcraft filter, it has the ADBV in the base instead of the head as per the Ford spec (obviously).
(Or the other way around, I forget)
Some people who have rattles on startup claim the Motorcraft filter solves the problem.
undecided.steve is offline
Old 04-07-2007, 01:05 PM
Quicktime_GT
Quicktime_GT's Avatar
I run 5w -30 mobil 1 synthetic and a motorcraft filter. A motorcraft filter is actually made by purolator. It has the "pure-one" internals.. with the regular "L" case. I was told by a guy at hang em high performance to switch to 10w -30. He says the oil pump will get weaker with miles as well as clearances not being as tight as they were when the car was built. He made a good point.. He went on to say that he see's cars all the time especially 4 valves where rod bearings have let go due to this. He also says a little thicker oil will cut down on some of the engine noise the 4.6 makes.
Quicktime_GT is offline
Old 04-07-2007, 01:39 PM
trumpet112001
trumpet112001's Avatar
AMSOIL 10W30 with AMSOIL FILTER BABY!
trumpet112001 is offline
Old 04-07-2007, 01:46 PM
WhItEvEnOm
WhItEvEnOm's Avatar
i use 5w 20 mobil 1 synthetic but i also use castrol gtx as well..........
WhItEvEnOm is offline
Old 04-07-2007, 02:05 PM
TOOT
TOOT's Avatar
Royal Purple or Mobil 1 full synthetic with a K&N gold filter
TOOT is offline
Old 04-07-2007, 03:40 PM
richinwa
richinwa's Avatar
One thing you don't relalize about the aftermarket filters like the K&N and the Amsoil filters, is that they have too much filter material in them. Use the Motorcraft filter! Manufacturer's spend a massive amount of $$ on design for stuff like that so the **** doesn't break down or in the case of a filter it doesn't clog. If you change your oil like you should at 3000 miles or sooner depending on how hard you run you car, all you will need is the basic filter and spend less $$$$$.
You people that through your hard earned money at a K&N oil filter and brag about it call me I have a bridge here in Tacoma to sell you.
richinwa is offline
Old 04-07-2007, 03:51 PM
sitnlopro99gt
sitnlopro99gt's Avatar
mobil 1 5w30 with wix/k&nfilter. Do what motor calls for...
sitnlopro99gt is offline
Old 04-07-2007, 04:33 PM
silver03gt
silver03gt's Avatar
There is a reason that these motors call for 5w-20, the tolerances in these mod motors are a lot tighter than the old motors, say a 5.0 or small block chevy, if you run thicker oil it can actually provide you with less lubrication,,, in my small blocks I always used to run 20w50, big no no in these 4.6's. I do agree that after you get up there in mileage, say 50k plus it wouldn't hurt to switch to 5/30 or 10/30 cause the tolerances arent as tight.As for the type of oil, I have always been a Castrol GTX fan, seen my mom's volkswagen scirroco go over 300,00 miles with NO engine problems running that stuff, but I recently switched to using The Motorcraft synthetic blend for my stang, I figure If it's good enough for ford and there warranties, it's good enough for me, plus it is the best bang for your buck in a blended oil, it costs the same as regular oil,,, I also run Motorcraft oil filter. As for your tranny, I'd go with Royal purple and the same in the rear end, don't forget to add a bottle of the friction modifier from ford to the rear end oil.
Just my .02, take it for what it's worth, everyone has there own preferences on this subject.
silver03gt is offline
Old 04-07-2007, 04:38 PM
1fast 99gt
1fast 99gt's Avatar
ORIGINAL: sitnlopro99gt
Thats what i do and thats what you should do
1fast 99gt is offline
Old 04-07-2007, 04:44 PM
jmac72187
corner carver
jmac72187's Avatar
My car manual says 5w30 and the cap says 5w20.
jmac72187 is offline
SSRFUZZY
Members Other Vehicles
01-06-2016 08:22 PM
ChampInSD
10-02-2015 04:55 AM
algregory
09-11-2015 11:44 AM
Pyrate Dave
09-10-2015 07:30 PM
cbird1177711
09-02-2015 08:51 PM
Quick Reply: what oil to run in my gt?
