sputtering
Old Apr 7, 2007 | 11:39 PM
theorgnlimprtkillr's Avatar
theorgnlimprtkillr
Default sputtering
I have a 1997 mustang gt 5-speed that when im going down the road it will start sputtering if you get on it to hard. I'm not sure but I think its starving for fuel and may need another fuel filter. please tell me what you think so maybe I can try to fix it. thanks.theorgnlimprtkillr
Old Apr 7, 2007 | 11:42 PM
sprostang's Avatar
sprostang
I ♥ Acer
Default RE: sputtering
Change the fuel filter first and get the injectors cleaned or try running a can of BG 44K fuel system cleaner in the gas tank after you change the filter.
Old Apr 7, 2007 | 11:43 PM
roush17's Avatar
roush17
Also, check to make sure your plug wires are in tight.
Old Apr 8, 2007 | 12:03 AM
rdmypny's Avatar
rdmypny
fuel pump i am having the same problem. starts acting up about 3,000 rpm's. changed my filter and didn't help so i called my mechanic and he said fuel pumpo so i went to www.uprproducts.com and ordered part number: 4006-2 walbro 255LPH pump. should be here wed.or thurs. then change your injectors to 24lbs
Old Apr 8, 2007 | 11:46 PM
theorgnlimprtkillr
v
ShaneB26154
35
Mar 4, 2021 04:05 AM
MEISTERSNFB
Mar 31, 2020 07:50 AM
mustang96gt
Mar 21, 2006 08:10 PM
SGTMack
Feb 7, 2006 04:40 PM
tokinGLX
Jan 8, 2006 11:50 PM
