Best ramps for the buck??
RE: Best ramps for the buck??
ORIGINAL: Slicktastyk Matt
Dammit! That's what Im wanting to do mainly is mess with my catback/midpipe. Also, I want to learn how to change my own oil. So I could make that and get jackstands? How much would those run me
Could I just use jackstands and wheel stoppers? I was looking at autozone's site again and found some 4 ton jack stands for like $30 by Larin?
if your catback is already installed then you shouldn't have a problem using ramps to adjust it or to change your midpipe. I know my catback needed adjusting after I installed it and ramps worked fine after I had the pipes over the axles
For changing the oil you should use the ramps for the front, and jack up the rear so it is LEVEL and use stands in the back... to get all the oil out the car must be LEVEL!
Thanks for the advic guys. Im wondering whether to just make my own or buy a pair of ramps. Because having the car held up by a jack stand would cause some serious paranoia under there for me I'm sure...soooooooooooo...ramps it is! [8D]
jwog666
12-27-2021 08:09 PM
mungodrums
10-07-2015 04:01 AM
Matt's 95 Stang
10-05-2015 07:16 AM
