Slit in tire?
Slit in tire?
I have BFGs and have only had them for maybe a month... Well when i was buffing my rims i noticed a slit in the tire thats maybe 6 inches long and deep enought to stick half a penny in..... Is this something i should worry about? Its on the top of the sidewall....
RE: Slit in tire?
ORIGINAL: sprostang
Blame the body shop for it. [8D]
Because i dont wana be going 100 down the road and have a blow out..
RE: Slit in tire?
its not uncommon at all to get little slits in the tread of your drag radials.. the rubber is EXTREMELY soft and if you run over something sharp planted to the ground it will do it really easy. Just make sure its not THROUGH the tread into the tire.
Also, make sure the tire isnt rubbing on anything. If its not, then it should be fine. You'll see those come and go as you wear out the tread on your tires.
RE: Slit in tire?
ORIGINAL: HaV
Hav are you going to that huge car show outside of OKC? Me and about 18 other stangers are going... You should ride with us
RE: Slit in tire?
And i wasnt so sure these were drag radials though?
http://www.discounttiredirect.com/di...&tc=MTAHZ9
jwog666
12-27-2021 08:09 PM
KingRando
10-02-2015 08:06 AM
nmra1965
Other Professional Racing
09-26-2015 10:46 AM
