daaaaaamn
Old Apr 19, 2007 | 11:54 AM
  #21
2000GT4.6's Avatar
2000GT4.6
Default RE: daaaaaamn
Anyone that really bashes autos or says they would never drive one obviously has never been in a properly setup auto car. I don't care if your john force himself, a properly built auto car with the right amount of horsepower behind it is simply faster, more accurate, and more consistant than any human could possibly ever be.
If I could start over, I would have tried to find a car exactly like mine with a auto in it. I went thru 2 45s before I got this TKO, and even with a far superior aftermarket trans things can still go wrong.
On the other hand, stock autos suck.
Old Apr 19, 2007 | 11:58 AM
  #22
jpmustanggt's Avatar
jpmustanggt
ORIGINAL: sprostang
, where do you get this stuff man?
Old Apr 19, 2007 | 12:04 PM
  #23
rainydayracing's Avatar
rainydayracing
If I went to the track a lot, I'd totally have an auto - it is the best setup for it. I don't go much, and really think the stick is fun.
Old Apr 19, 2007 | 12:31 PM
  #24
contentsunderpressur's Avatar
I had a 98 gt before the one I have now. It had exhaust and gears and shattered 3 T 45s from speed shifting. I'm still running the stock 3650 in my 03 and have had 400 hp run through it for nearly two years with no problems. I have also never speed shifted this car because of the luck I had with the nearly stock weak 98. The 3650 can handle a lot but just can't handle speed shifting. If you feel that you have to speed shift then go with the TKO.
Old Apr 19, 2007 | 01:42 PM
  #25
InferRedd's Avatar
InferRedd
That sucks.
Some thing happened to me when I power shifted to second. But I have to hold the gear in while letting off the clutch or it will pop right out.
96' GT
Old Apr 19, 2007 | 01:44 PM
  #26
bjh061487's Avatar
bjh061487
good luck been there done that in my old jeep
Old Apr 19, 2007 | 02:14 PM
  #27
ih8chevy's Avatar
ih8chevy
I dont kno i think that the wci t5 that was in the 5.0s was pretty bad too
ORIGINAL: 2000GT4.6
ORIGINAL: Colorado_Mustang
You lost to a Firechicken.....[sm=icon_rofl.gif]
Seriously, work on your driving a little bit. No reason a little 4.6L SOHC will bust up a T-45 or 3650.
The T45 is simply the worst manual tranmisssion to ever be put in a V8 mustang. Even one missed shift/overrev and you are done, its only a matter of time before the syncros go out.
I went thru 2 T-45 with just simple boltons on the car (even with the good driver mod) and said screw it.
The rebuild will be cheaper, but save yourself money/headache down the road and just get a TKO/T-56. It will break again if you continue to powershift (no matter how good you are) as the syncs just cannot handle power/speed shifting. The TKO does not have the same problem.
Old Apr 19, 2007 | 02:39 PM
  #28
droptoppony's Avatar
droptoppony
Time to get a T-56...
KingofUSMC
Sep 10, 2007 03:41 AM
