suspension package
Old Apr 23, 2007 | 12:20 AM
83700stang's Avatar
83700stang
Default suspension package
hey guys, tomorrow i will be full bolt-on after i put the pulleys on, finally on my 00'. im not looking for drag suspension or anything crazy, and a 1 1/2 drop at the most. does anyone recommend dropping 1" back and 1 1/2" front? figured the stance would look better. and what suspension package would you most recommend for a daily driver. springs, struts. caster camber plates?strut tower brace? and what about Dugan Racings' suspension packages? any help would be greatly appreciated.
Old Apr 23, 2007 | 12:24 AM
racer02GTstang's Avatar
racer02GTstang
Default RE: suspension package
if you can afford it, a whole front coil over kit with k member etc... then struts/shocks, CC plates, full length subframe connectors, strut tower braces...
Old Apr 23, 2007 | 12:27 AM
sprostang's Avatar
sprostang
I ♥ Acer
If you only want to do a 1.5 drop. Go with the eibach pro kit. It will drop the car 1.5 front and rear and you shouldn`t need cc plates.
2000GT4.6's Avatar
2000GT4.6
ORIGINAL: 83700stang
For a great DD setup, all you really need is a set of adjustable shocks/struts, springs of your choice, and some lower control arms. You can add to that list if you really want to, but those are the three things that will effect the car themost while still staying within a budget and being something you can install yourself.
I went with a 4cyl fox front spring and the roush racing springs in the rear, but I think the roushes in teh front and back would have about the same effect:
[IMG]local://upfiles/4605/D6520809349B4498BEFC27DC02F3A966.jpg[/IMG]
This is a before picture:
[IMG]local://upfiles/4605/9BE46E499023455DBFA1F4C0B3FB7DF1.jpg[/IMG]
jrrhd73must
Oct 2, 2015 09:17 PM
ChampInSD
Oct 2, 2015 04:55 AM
marc954
Sep 29, 2015 11:18 AM
mungodrums
Sep 28, 2015 10:54 PM
