Which subframe connectors? Ordering tonight.
Old May 8, 2007 | 08:32 PM
CoolAid's Avatar
CoolAid
Default Which subframe connectors? Ordering tonight.
Need your opinions again guys. Going to buy some weld up sub frame connectors for the GT. Installation is not an issue, I got that covered, but which set of connectors would you order for your GT? Thanks for your opinions as always.
BTW, I'm leaning toward the Maximum Motorsport connectors (price is not a concern, but I listed it anyway)
See links for more description:
1. http://www.americanmuscle.com/maximu...onnectors.html
2. http://www.americanmuscle.com/stfulesuco.html
Old May 8, 2007 | 08:37 PM
97stanger's Avatar
97stanger
Default RE: Which subframe connectors? Ordering tonight.
MM ftw!!
Old May 8, 2007 | 09:22 PM
CoolAid's Avatar
CoolAid
Just ordered the Maximum Motorsports connectors. Thanks!
Old May 8, 2007 | 09:27 PM
yelw02GT's Avatar
yelw02GT
i paid 40 dollars for mine from mustangs unlimited..they do the same thing has the over 100 dollar ones
Old May 8, 2007 | 11:17 PM
/\CHRIS/\'s Avatar
/\CHRIS/\
What about the matrix kit on RPMOutlet.com THey have a huge setup for the mustangs.
Old May 8, 2007 | 11:28 PM
Aereon's Avatar
Aereon
ORIGINAL: yelw02GT
They do not do the same thing, the no name subs are just bars that have no r&d put into them, they have no engineers studying the affects of their sfc's on handling or worse yet they copy the design of one of the more reputable companies (mm or griggs) and send it oversee's to make and call it there own...
MM and Griggs suspension parts are expensive because of all the research and time they spend developing parts that do what they are specifically designed to do and are still top notch in durability.
You pay for what you get, and hopefully the iron bar you got from mustangs unlimited is shaped right to conform to your floor pan and your welder did not force it on.. or your chassis will be slowly bent by the bar..
Old May 8, 2007 | 11:34 PM
97modifiedmustangGT's Avatar
97modifiedmustangGT
You could have got the MM from www.stangsuspension.com for 114 bucks then you get a coupon code.
But on a better note you did get yourself some nice sub frames. Good choice!!
Old May 8, 2007 | 11:37 PM
barbiaux's Avatar
barbiaux
i have a convertible, do they come stock with these connectors. I have 2 bars underneath that I have no idea what they are and they look like the pics from those websites listed above
Old May 8, 2007 | 11:41 PM
Aereon's Avatar
Aereon
ORIGINAL: barbiaux
you have standard length sub frames. I would recommend getting full lengths to increase your chassis rigidity, but I do not know what other vert owners do, not sure if they have someone take the standards off and weld up the new ones or if there is a reliable way to extend them.
laserred38's Avatar
laserred38
yes they do, but they are cheapy ones and are bolted on i believe. you should upgrade.
jwog666
Dec 27, 2021 08:09 PM
bradleyb
Nov 27, 2015 07:50 PM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
Drastang
Sep 30, 2015 03:48 AM
GLOCKer
Sep 28, 2015 07:36 AM
