Block decision?
RE: Block decision?
if you wanna build a motor from the ground up and put it in a 1996, i suggest a 5.0 they have much more aftermarket parts compared to the 4.6 and the parts are cheaper and easier to find. you can just go to a junkyard, and find a 5.0 for 100 bucks strip it and there you go.
RE: Block decision?
all of your electrical will work with the new PI engine, you just have to use your coil packs and fuel rail instead of using the COPs off a 99-04...this way your stock ecu/harness will work perfectly. You will just have to get a dyno tune to take care of the rest.
RE: Block decision?
Yeah, I am thinking of going either vt stage 2's or anderson's N42's on mildly ported heads, a forged bottome end, and a sct or predator tune. Long tubes and bigger tb, A LOT OF GIGGLE JUICE. and 30 lb injectors.
Matt's 95 Stang
10-05-2015 07:16 AM
