Raising compression
RE: Raising compression
well, remember the more compression you have, the less boost (if you plan on F/I) you can run in the future. instead of just milling the heads (.036 seems like a bit much) id just go with a stroker if you dont plan on F/I that way you got that torque and compression.
i really wouldnt mill the heads, you throw it out of wack, and youre going to have an expensive repair job. only time i heard of milling the heads is on a repair job, ive never heard of someone doing it to "gain" HP. id just go with better flowing heads if you want power, or a P and P
ccdguy
09-19-2015 05:20 PM
