Help, I can't Burn Rubber
RE: Help, I can't Burn Rubber
ORIGINAL: Emann0007
Hmmm.... maybe thats because your e-brake locks up the rear...Just maybe.... I can smoke the tires with little or no brake pressure at all, but not like a manual. The slushbox makes the power transfer a lot weaker. If you can't burn rubber driving a GT, you need to cut up your license!
I just use my E-brake then try to spin the tires.... Doesn't work for some strange reason
burn outs r fun maybe that why my rear tires r almost bald LOL
my dad always tells me that burn out r really bad for ur car. they r just bad for ur tires. right? once ur tires start spinning their isnt that much force on the car (like the engine, tranny, flywheel, cams, rears end). or im i just miss informed?
ORIGINAL: DVS99GT
As far as burning tire goes, in stock form mashing it from a stand still in my car the tires will start to break loose alittle and mines a 5 spd. I wouldn't expect to much tire burning from pulling out fast stock. If you really want to burn tire you can brake tourqe it or get a line lock. Line lock is alittle better for the car because your rear brakes aren't being held on.
yeah u dont want to f up ur rear break pads. i dont use the break. i just drop the clutch at a high rpm i dont burn out for long periiods of time either just for a few seconds to put some rubber on the pavement
lincolnshibuya
12-08-2015 04:37 PM
