View Poll Results: A poll
Accufab Plenum + 70mm TB (NA)
0%
Accufab Plenum + 75mm TB (NA)
0%
C&L Plenum + Accufab 75mm TB (NA)
0%
Other.....
0%
Accufab Plenum + 70mm TB (SC)
0%
Accufab Plenum + 75mm TB (SC)
0%
C&L Plenum + Accufab 75mm TB (SC)
0%
Other......
0%
Voters: 0. You may not vote on this poll
Intake Setup
RE: Intake Setup
C&L with the 75mm Accufab. For both
Accufab and Accufab is also a good configuration (already polished) little pricy.
Depending on where you look the c&l setup outperforms the accufab setup and visa versa. I got the C&L setup and going to port and polish the plenum the end of the month.
Should net me 8-12RWHP easy.
RE: Intake Setup
Found at Accufabracing.com
1996-2004 4.6L
2V PLENUM FLOW RESULTS 5" 20" 25" 28"
C&L Plenum
w 70mm Accufab T/body 235 470 526 557
w 75mm Accufab T/body 252 504 564 597
Dragon Plenum
w 70mm Accufab T/body 258 516 578 611
w 75mm Accufab T/body 261 522 585 619
ACCUFAB PLENUM
w 70mm Accufab T/body 265 530 594 628
w 75mm Accufab T/body 265 530 594 628
1996-2004 4.6L
C&L Plenum
Dragon Plenum
ACCUFAB PLENUM
RE: Intake Setup
ORIGINAL: GT1999
silverGT... your gonna port the c&l plenum? isnt it already good enough, i dont see how much more power u could get from porting the already aftermarket c&l plenum.... 2 hp?
Livin' - Depending on where you look the C&L setup versus the Accufab set are basically equal. I think it was in 5.0 they did the compare and the C&L with the 75mm Accufab beat out the Accufab set-up, but poke around online and you see the opposite. Basically that difference (1-2hp) can be ac****ed for through conditions of the weather and/or the condition of the car. I look at like the Accufab is already polished and the C&L is right there, so if I polish the C&L it should give me the supposed few that the full Accufab has over it, again depending on where you find your info.
RE: Intake Setup
ORIGINAL: LIVIN_LEGAND
1996-2004 4.6L
C&L Plenum
Dragon Plenum
ACCUFAB PLENUM
1996-2004 4.6L
C&L Plenum
Dragon Plenum
ACCUFAB PLENUM
From what I see I don't think the accufab picked up 30hp or tq or whatever the number means. Going to need an explination or atleast a link.
RE: Intake Setup
Looked a little, that is a CFM comparison.
Guess what?
It doesn't matter how much more air you flow unless you are in a FI set-up. Having to much CFM can hurt the performance of a motor. If more was better you would be putting 100mm TB on a car 75mm set-ups on a NA car in an poor setup can hinder performance.
There is a limit on how much CFM a car should have to give the best benifit. To make/say that the accufab set-up is the best one soly based on CFM is unwise. CFM is not a measure of power just the ability to flow air.
For argument sake the C&L and Accufab setups are basically equal in a NA application. The accufab may have a slight edge on a FI set-up. But the C&L still has material to spare for port/polish. Were I believe the Accufab is already polished.
Guess what?
jwog666
12-27-2021 08:09 PM
daltron
04-28-2016 08:10 PM
