DIY intercooler interesting information
#21
RE: DIY intercooler interesting information
ORIGINAL: 2000GT4.6
I believe the paxton has a different setup gear wise, so a different pulley will yeild different results.
#23
ORIGINAL: 1BadSonicBlue02GT
yea but the way i look at it is ten pounds of boost is 10 lbs. As long as you can get it you'll be ok.
#24
I would imagine that having the 1000 makes a difference too, instead of a 2000. A 2000 shouldn't be using the smaller pulleys, they are capable of LOTS of boost.
I could have gone with a 2000 on my MPH kit for another few hundred bucks, and I wish I had for the future. Its going to hurt buying that T trim down the road.
#25
I'll more than likely buy a PP from mph and see if they can weld me a bung for use with the mini race.
If I end up making too much boost I'll just have to take it easy and possibly set the limiter at 5500 or so. Couple people I've talked to see 11psi with a 3.1, IC and PP.
