pros and cons??
Old Jul 9, 2007 | 08:37 AM
dgantt's Avatar
dgantt
Default pros and cons??
Hey guys, I hope I'masking this in the right place. I was thinking of adding a aluminum drive shaft. What are the pros and cons of that mod? Also I was thinking about the aftermarket coil packs, an comments. As always thanks.
Old Jul 9, 2007 | 09:11 AM
mylongvictor's Avatar
mylongvictor
Default RE: pros and cons??
This will either get deleted or moved to General section by my guess...... but here is my answer to your question....
Pros - Stronger, lighter, better then your stock cast iron driveshaft
Cons - None that I officially seen but, I belive that was an article in MM&FF a year ago where I read that some users still had too much torque and was still able to twist the driveshaft off the joints.
Other then that I believe its a good mod to have when you start making serious power.
Old Jul 9, 2007 | 09:33 AM
dgantt's Avatar
dgantt
Thanks, I thought I mught put it in the wrong section. I'll post it in the other.
JoshyGT
Sep 19, 2017 08:52 PM
mapitts
May 11, 2016 10:14 AM
jerrytubes
Oct 23, 2015 12:11 PM
PB Pod
Forum Issues and Feedback
Sep 17, 2015 08:32 PM
Doogie65
Sep 6, 2015 02:55 PM
