Throttle Position Sensor
Old Jul 14, 2007 | 05:43 PM
Marchant03GT's Avatar
Marchant03GT
Default Throttle Position Sensor
hey guys i swapped out my tb/plenum with a accufab. but then put my stock back on something was wrong with the accufab. now my tps is on my check engine light. i took it back off and tried doing it again. but its still has check engine. i got the diablo preditor i cleared it after i fixed it and it still did it. any idea were i can buy a new one like a website. i need one before i go to the track next week
Old Jul 14, 2007 | 06:03 PM
LetThePoniesRunFree's Avatar
LetThePoniesRunFree
Default RE: Throttle Position Sensor
I'm going to assume you used the factory TBS on the Accufab?
Why would you swap out your TB/Plenum because of a TBS CEL?
Did you index the TPS properly?
Old Jul 16, 2007 | 01:16 PM
undecided.steve's Avatar
undecided.steve
ORIGINAL: Marchant03GT
Did you adjust the TPS to .98 volts or so with the ignition switch "on" but car not running?
Are you sure you put the TPS on correctly?
You have to get the shaft into the slot of the TPS before you snug down the screws.
What was wrong with the Accufab unit?
Old Jul 16, 2007 | 06:42 PM
Marchant03GT
the accufab unit ran at like 3grand and i didnt change anything just bolted it on.. and it went ape **** on me.. i didnt buy it, it was my buddys so i gave it back
Old Jul 17, 2007 | 09:50 PM
jishead's Avatar
jishead
Certainly check for the .98 volts as stated above. Check that the butterfly is not 'sticking' too far open (a little open may be acceptable via set screw, but not like due to carbon buildup or interfearence or cable kinks.) Double check the vaccuum lines making certain you are not sucking unmetered air. Check that your TPS is not 180 degress out of index (from memory, it's like a knife blade and possibly to get rotated wrongly I think - been a while since I did mine). Also - a TPS can go bad. I bought a TB from E-bay (just to port and polish it) and the TPS that it came with had similar symptoms no matter what I tried. Luckily my OEM TPS is still fine. Hope this helps.
jwog666
Dec 27, 2021 08:09 PM
mrtrodonet
Sep 19, 2020 03:12 PM
lincolnshibuya
Dec 8, 2015 04:37 PM
Dathan
Oct 5, 2015 05:52 AM
UrS4
Oct 3, 2015 06:23 AM
