Erratic idle problem
Old Jul 17, 2007 | 04:40 PM
V1PWRED's Avatar
V1PWRED
Default Erratic idle problem
Ok, so the car isnt idleing well, goes up and down slow, strong fuel smell to...Ive narrowed it down to these-
-Possible small vaccum leak at intake manifold, checked all hoses, everything seems fine though it still sounds like a slight hissing somewhere...cant pinpoint over the s/c whine
-Bad 02 sensors...they havent been replaced in a while however there is no CEL
-small header leak
-Spark plug gap? I doubt this, but they are gapped for the s/c and at the moment the car is not boosting...so mayby?
any other possibilites or suggestions would be nice
Thanks
Old Jul 17, 2007 | 05:21 PM
jpmustanggt's Avatar
jpmustanggt
Default RE: Erratic idle problem
Most of the time with something like that it's your IAC valve. It's right next to the throttle body.
Old Jul 17, 2007 | 05:44 PM
blackstallion666's Avatar
blackstallion666
i'd check the iac first but i would possibly look into a bad fuel injector. you may have a fuel injection being mechanically stuck open. which would explain the fuel smell a rough idle.
Old Jul 17, 2007 | 08:07 PM
V1PWRED's Avatar
V1PWRED
ORIGINAL: blackstallion666
This is an interesting thought as there is a very high pitched electronic like noise, which i thougt may be a vaccum leak as stated, could very well be an injector just dumping fuel in... The IAC is good, i checked the voltage as the book describes. Any idea how i could pinpoint the injector...Mayby just go through and unplug them one at a time until that high pitched noise goes away
Old Jul 17, 2007 | 08:44 PM
blackstallion666
unpluging may pinpoint it. unplug them one by one. and obviosly is should have a miss on what ever cylinder you unplug but if the engine seems to run the same when you unplug the injector or the noise goes away thats is more then likely the bad injector. becuase that injector is stuck open and still dumping fuel even though it is not connected. i hope this helps.
Old Jul 17, 2007 | 09:29 PM
^iLLuSiOn^'s Avatar
^iLLuSiOn^
if an injector was to get "stuck open", or bad oring on one you would be dumping fuel in to the cylinders with only the key on, you would most likely lock the engine and not even turn over, does it sound like an exhaust leak? are all the spark plugs tight?
Old Jul 18, 2007 | 09:06 AM
V1PWRED's Avatar
V1PWRED
ORIGINAL: ^iLLuSiOn^
I do have a header leak on the drivers side, but this noise is very high pitched...hard to hear over the s/c but definatly there...Though it might be a vaccum leak, but the noise sound electronic...Ill try to unplug them and see what happens, ill also check my plugs as they were changed recently
Old Jul 23, 2007 | 12:18 AM
zsimp's Avatar
zsimp
to check injectors, if you can reach them, put a screwdriver on em, and put your ear up to the end, you should hear them clicking. its them opening and closing, if there is no clicking, you've found your stuck injector.
Old Jul 23, 2007 | 03:46 AM
cliffyk's Avatar
cliffyk
TECH SAVANT
A header leak can foul up the a/f ratio being seen by thefront sensor on your driver's side (bank 2)--this could cause the PCM to "hunt" to try to find the correct fuel trim...
Old Jul 23, 2007 | 03:04 PM
Dan04COBRA's Avatar
Dan04COBRA
You have too many fixes going on at once. First thing you need to do is fix the exhaust leak & work from there. This could be throwing your O2 sensors off and give you a rich smelling exhaust & irradic idle, sometimes it's not enough to trip the CEL.
2007CalSpec
Dec 13, 2020 11:42 AM
2007StangV6
Jan 28, 2016 06:09 PM
96stang3.8
Sep 10, 2015 06:42 AM
94stangnewbe
V6 General Discussion
Sep 7, 2015 07:39 PM
Emblazoned
Sep 3, 2015 10:45 PM
