evrything went wrong
Old Feb 11, 2008 | 07:22 PM
texas_stang02's Avatar
texas_stang02
Default RE: evrything went wrong
i know what you mean about the plugs, getting dirt down in there. when i change my plugs out, i pull the coils off and use my air compressor to blow all the dirt out of there before i start taking the plugs off. i'm thinking about getting some rubber and cutting it so that it slips around the rubber tubing on the coil, and cutting the outside so that it has a snug fit inside the spark plug hole... to keep dirt from getting in there in the first place (some cars come with this sort of thing from the factory but i guess it didn't come across the Ford engineers' minds). another place dirt likes to collect is around the valve cover bolts, so if you ever take off your valve covers be sure to blow that dirt away too, otherwise you'll end up with dirt all inside your cylinder head, which is worse than getting it inside the combustion chamber (at least the combustion process pushes the dirt out through your exhaust.. if it gets in your oil, it can really mess things up).
Old Feb 11, 2008 | 07:25 PM
texas_stang02
ORIGINAL: GT1999
do u know if the NGK iradium plugs come gapped right out the box?
i doubt any spark plug is going to come out of the box with the right gap for your application, and if it does then it's probably coincidence. it will be close, but not all engines require the same gap so they usually set it a little tight so that you can open it up with a gapping tool to get it where you need it.
Old Feb 11, 2008 | 07:27 PM
ZW99GT's Avatar
ZW99GT
Seriously guys? 3+ year old thread about changing spark plugs?
Old Feb 11, 2008 | 09:21 PM
kenv's Avatar
kenv
ORIGINAL: ZW99GT
I wonder if he got it fixed since the original post
Old Feb 11, 2008 | 09:41 PM
texas_stang02
ORIGINAL: ZW99GT
haha i didn't check the date on the original post.. never do really
Old Feb 12, 2008 | 12:26 AM
Mjaga251's Avatar
Mjaga251
ORIGINAL: ZW99GT
Now that;s funny. I didn't even realize it!
I'm assuming it's fixed considering he hasn't posted anything in this thread for that long!
Old Feb 12, 2008 | 02:11 AM
Mr Graystang's Avatar
Mr Graystang
[sm=laughat.gif]
vargas
Jun 17, 2017 12:17 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
marc954
Sep 29, 2015 11:18 AM
Offendant
Sep 23, 2015 07:21 PM
Demodulates
Sep 18, 2015 11:14 AM
