is my ac compressor shot?
My car is making a dreadfull ticking/rattling sound from the front. It sounds like a chain is loose and slapping around. The sound goes away when I turn the ac ON, and returns when I turn it OFF. At 1st i thought timing chain, but the idol is smooth and sound is comming from the compressor area. I also thought I smelt a burning smell when the ac was ON when I was comming home from work(electrical wire melting smell). I have a fire exst. in the car with me but I did not have to use it(thank god) I am thinking its the compressor and was just wanting someone who has some experiance with this to hoppfully share their 2cents. thanks
RE: is my ac compressor shot?
The compressor clutch will make a putrid burnt smell when it slips badly, and they do make a rattlely sound when the bushings/bearings are bad. There's no real fire danger, however it will only get worse.[/align][/align]Be advised that if the idle wheel bearing on the AC clutch fails completely you will shred you serpentine belt, which equals no engine cooling, which equals fix it where it is or get towed...[/align]
I am having almost the same problem. At Idle I get a noise that sounds like a bad bearing rotating, but this happens with the AC on or off now. AC works intermittantly andafter I drive for a while I can see the AC pully is moving slower than the Serpentine belt and the belt starts burning up.
Is it easy to just change the AC Clutch? I have never done this before. Any special tools required?
ORIGINAL: DSGSTANZG
go to an autozone and buy the ac clutch. it should cost like $130 i think.
also rent a pulley puller from them, you'll need a pair of retaining clip expanders too.pm me if you need anymore info or step by step instructions
ccdguy
09-19-2015 05:20 PM
