Normal Leak??
#21
RE: Normal Leak??
ORIGINAL: Dan04COBRA
It's your AC...for sure.
I'm surprised nobody said "bearings" or "yer engine is bad".
#22
RE: Normal Leak??
#23
RE: Normal Leak??
ORIGINAL: Derf00
I'm sure some noob would've stated that eventually. Seems to be that time of the year. I've already nailed two in the V6 section. (one for saying the 99-04 mustangs and the 03/04 cobras have incompatible rear suspension systems (meaning you can't swap) and the other stating the 99-04 V6 have the front O2's in the header)
#26
RE: Normal Leak??
Holy crap, the water inside the metal in your block is leaking out!!! Time for a new engine!
But, I'll stick with the AC thing. I've never had mine hit the exhaust, I just get the normal tick-tick when shut down.[&:]
#27
RE: Normal Leak??
ORIGINAL: lizzyfan
+1, A/C
ORIGINAL: tbirdscwd
You'd be surprized at how much condesation can come off of the A/C lines especially in really hot climates. All that water has to drain somewhere, otherwise it would end up on your carpet.
i just ran my car for 3 miles with a/c and the condensation was dripping just from that little run. While i was checking the oil level i could hear it hittingmanifold and sizzling......
Follow the lines the run by firewall on passenger side you will definetly see where the water goes to
lincolnshibuya
12-08-2015 04:37 PM
breaking
10-02-2015 01:27 PM
