Do 99-04 GT's run rich from the factory?
RE: Do 99-04 GT's run rich from the factory?
ORIGINAL: LetThePoniesRunFree
14.6:1 at idle to ~3K after the car is warmed up. Above ~3K and at wot, it shouldrichout to around ~12:1 on a n/a car.
12:1 is around FI territory (abit lean FI). For reference, I picked up 8 WHP when n/a going from 13.1 to 13.4 a/f ratio (turned off the diablo chip that was causing the car to run rich).
+1 on the fact that they run rich from the factory. just use 87-89 octane gas cause that is what is recomended for or cars from factory. Should get a tuner to fix that.
ORIGINAL: 2000GT4.6
12:1 is WAY to rich on a n/a car. You want the a/f ratio around 13.60 to 14.00 on a n/a car.
Later
