HELP!!
Old 08-11-2007, 09:51 PM
Machmax777
Machmax777's Avatar
Default HELP!!
I put a off road x pipe on my 04 mach1 and installed steeda mil eleminators. like a dummy i wiped of the 02 sensors with my hands[sm=badidea.gif] and of course 3 days later they went bad and the check engine light came on. about 2 weeks later i replaced the bad 02's with 4 new bosh. today the light came back on[:@]. im clueless to what the heck is going on. thanks for any help.
Machmax777 is offline
Old 08-11-2007, 09:53 PM
964.6gtstang
964.6gtstang's Avatar
Default RE: HELP!!
have you checked to see what the code is
964.6gtstang is offline
Old 08-11-2007, 09:56 PM
Machmax777
Machmax777's Avatar
Default RE: HELP!!
havnt gotten the chance yet, im planning to monday. but my gas mileage is crap wich makes me think that it is the 02's again
Old 08-11-2007, 09:58 PM
Cornbread01
Cornbread01's Avatar
Default RE: HELP!!
did you reset the comp. unplug battery for about 5 mins. also may be bad mil eliminators.
Cornbread01 is offline
Old 08-11-2007, 10:01 PM
964.6gtstang
Default RE: HELP!!
could be a tune up on the gas part...when i got my 96 the guy said they didnt need mill elliminators untill 99 but he also said that 12psi is good for fuel injection uummmmmm so i have a code checker and it was saying system too lean bank 4,8,1 i got a pair for 50$ and it shut the light off
Old 08-11-2007, 10:02 PM
Machmax777
Machmax777's Avatar
Default RE: HELP!!
yes the comp got reset at the transmission shop (they put the 02's in) so the mil's being bad is what i was thinking to. is it common for them to not work?
Old 08-11-2007, 10:04 PM
964.6gtstang
Default RE: HELP!!
never heard it but any thing is possible
Old 08-12-2007, 07:43 AM
contentsunderpressur
contentsunderpressur's Avatar
Default RE: HELP!!
Did you put the MIL's on the front two sensors or the back two? If you put them on the front two then that's your problem. You don't use them on the front two because they're the ones that do the reading. The two back ones are there to let you know if you have a problem with your cats. All the MIL's do is give the computer a certain reading from the two back ones so the light don't come on. Sounds like you don't have any on the back or you put them on the front.
contentsunderpressur is offline
Old 08-12-2007, 09:21 AM
livefast1
livefast1's Avatar
Default RE: HELP!!
bad front o2 sensors would affect gas mileage. rear o2 sensors arent used by the ecu to control the fuel maps. they are just a way to show that the catalytic converters are working properly.
livefast1 is offline
Old 08-12-2007, 09:44 AM
Machmax777
Machmax777's Avatar
Default RE: HELP!!
nope i put em on the back
