How to replace wheel studs?
RE: How to replace wheel studs?
So which is it? Will I need to take out the axle on a New Edge to replace the studs? Or can I just knock them out?
This video makes it look so easy
http://www.expertvillage.com/video/4...=yssp_mainvids
too bad thats not a stang.
There's NO need to pull an axle. I did mine in my garage last month and it was a breeze.
This guy explained it perfectly.
ORIGINAL: 8banger
you have to pul the Brake caliper and bracket...Remove the rotor...drive out the bad stud and use a stud installer.....Its really no big deal......
OK, so I finally got to it and banged the stud out. I was a little skeptical cuz of some of the other things I had read (pulling axles, etc.), but ZW99GT and 8banger were right on the money. Absolutely no need to pull the axle or take ABS rings off. I snaped a couple pics and thought I would put them up.
I hammered it out, once loose it was at an extreme angle to clear the ABS ring, but it did come out with a little banging. Once putting the new one on, again extreme angle but I used a lug nut to pull it through and the rest was history.
Hope it helps somebody else down the line.
