bypassing A/C?
bypassing A/C?
i want to bypass my a/c pulley, what size difference will the belt have to be, and what the hell is the pulley under the idler pulley. my hanes manual doesnt show what it is and i cant find out what it goes to
RE: bypassing A/C?
The idler pulley is on top of the tensoiner pulley. You would use both of them for the A/C elimination. You can go to the parts store and say you have a 96 GTS, a model ford came out with that was a completely stripped down GT. I believe there were some without A/C. If you have no luck there, you can cut your belt and wrap it around the way it needs to go and tape it into place and have it sized at the parts store! Not sure why you want to eliminate the /C unless you are having trouble with it, but if you went with Underdrive pulies you will net about the same power increase and still retain your air.
mrmrultimate
Texas Regional Chapter
09-10-2015 09:43 AM
