35-40 TIRE PRESSURE??
Old Aug 25, 2007 | 06:29 AM
undecided.steve's Avatar
undecided.steve
Default RE: 35-40 TIRE PRESSURE??
ORIGINAL: beastzilla02
what do you guys have your tires air pressure at for daily driving...i just filled all mine up to about 37-38...
If you have the stock tire size, then whatever it says on the door sticker.
Old Aug 25, 2007 | 02:49 PM
NeedStangSpeed's Avatar
NeedStangSpeed
ORIGINAL: undecided.steve
Far as I know and learned, you should always go with this. Dealerships and tireshops usually do too. I've always done it and never had a problem with it. Doesn't mean it right or wrong though. Anything's possible on this site.
Old Aug 25, 2007 | 10:43 PM
StickShifty's Avatar
StickShifty
you should have a sticker on the inside of the fuel door, i believe it says 30 psi at all 4 corners. i fill mine up at 30-32. 40 is wayyy too high.
Old Aug 25, 2007 | 10:52 PM
Xemeth's Avatar
Xemeth
ORIGINAL: yourmom6990
if the max is 44psi, you should set to about 40ish.
No way. You won't be running on the whole tire if you do it that high.
I usually fill mine to about 32ish. My guage sucks, so it's usually around 30-34 or something.
jwog666
Dec 27, 2021 08:09 PM
CS2007
Jun 25, 2019 09:45 PM
svfetter
Oct 5, 2015 11:39 AM
88 orangepeel notch
Oct 5, 2015 09:03 AM
marc954
Sep 29, 2015 11:18 AM
