Window not raising?
Hey guys i don't know what wrong but my window (driver side) doesnt goup, and it rainy couple of day here in GA. The motor makes a light clicking when i press down, but i does nothing on the way up. Is it the motor? does anyone have one
? or can it be some relay switch? all other window work fine.
I would get a wiring diagram for the window motors/door. See which wire it is that feeds power to the switch and motors. Make sure they are getting power, and make sure the switch is functioning properly. If that checks out its more than likely the motor has gone bad.
Yeah I just took off the panel and couldnt even see the motor everything is so hidden. Im gonna try to run a bypass and see if the motor will go up or not. thanks guys. How much are those motor anyways
ive had this happen like 10 times. just take the panel off, get a hammer and hit the metal track that you'll see on the left side of the door. ( while holding the up button for the window). But i do have bad news for ya, idk what it is, but the times this happened i had a bad bulb, switch, or wire in my car somewhere, so not to give you nightmares or anything but just a heads up. But then again it could have just came off track. but the hammer thing will work.
ORIGINAL: mustangchris09
DreadPirateRoberts
Sep 26, 2015 02:11 PM
ccdguy
Sep 19, 2015 05:20 PM
