emissions
emissions
okay, my CEL is on and i have to get emissions within the next couple of days. if i disconnect the battery and the light goes away will i pass emissions? or when they hook it up to the computer, will it still show the codes for the o2 sensors?
RE: emissions
If you reset your computer it will not work, I tired it and when they pluged it in they were unable to communicate with it or something like that, so theyhad to run it on the sniffer, which i failed. I would just get the code read and either fix it or just erase it and then go to emissions
RE: emissions
i just read that your cel is on for a o/r pipe, you will need to get mils or a tuner to turn them off, I am not sure if you clear the codes if you will pass or not, but if you do a hard reset you will not pass by being plugged in
RE: emissions
every county has different rules, i passed with a o/r h pipe and mils, if you dont have a visual inspection and they only plug in to your car you will pass if you get the cel off with out a hard reset
RE: emissions
ORIGINAL: jst854
If you reset your computer it will not work, I tired it and when they pluged it in they were unable to communicate with it or something like that, so they had to run it on the sniffer, which i failed. I would just get the code read and either fix it or just erase it and then go to emissions
mrappe
09-26-2015 10:16 AM
jpplaw
08-22-2015 09:29 PM
