Proper way to clean engine and bay area
RE: Proper way to clean engine and bay area
you can use a pressure washer haha ive done it few times, now i just spray foamy engine bright on there and wash off with hose..and the only thing i keep water away from is airfilter, MAF, and the fuse box,and at that i dont even cover them, i just keep the water away from those areas, everything else is fairgame
You can use a pressure washer. i remove my air filter,stick an old t-shirt in the inlet tube,soak the engine with degreaser,let it sit ~15 mins. hose it down with the pressure washer,make sure the inlet tube is dry,put the filter back on and fire it up.
good job... might i suggest you do a spoiler relocation... look at my photo gallery so you can see what it looks like also did you paint your rims or were did you get them???
ORIGINAL: Cornbread01
Yea... it looks sick from a distance... but the body lines dont match up for ****! The spoiler actually goes over the sides a bit! NOT CLEAN!
Cornbread... I do however like your hood! nice match job with the vinal top color! Looks good!
ShaneB26154
35
03-04-2021 04:05 AM
Gary Ugarek
09-05-2015 09:03 PM
