you need to keep your pre-cat O2 sensors hooked up, your car will run very bad if they are not. but if the post cat O2 sensors are not you will just throw a code. The post cat o2 sensors just tell you if the cats are working. The pre-cat o2 sensors are the important ones, they tell the engine whether its running lean or rich, so keep the pre cat ones installed, you can take off the post cat, but no real reason to
yeah and make sure you at least plug the rear o2 sensor holes up, even if you dont want to use o2 sensors, because it sounds really raspy if you leave those holes open.... trust me. You think it sounds cool for a day but then u put them back on and say "damn, my exaust sounds so full now"
