Boost
Old Sep 22, 2007 | 10:31 AM
289boss's Avatar
289boss
Default RE: Boost
I have also order a programmer and another pulley to the charger. So i can run 15 psi. The supercharger i have can give on max 32 PCI and 800 Hp.
Old Sep 22, 2007 | 10:53 AM
Cornbread01's Avatar
Cornbread01
Default RE: Boost
if your gonna run 15psi on a stock bottom end 2v without a dyno say by by motor. even with just 10psi and no dyno tune its just a matter of time
good luck
Old Sep 22, 2007 | 11:00 AM
mfj's Avatar
mfj
Banned
Default RE: Boost
p1sc cannot reach 32 psi!!!!!!! Go ahead and call procharger and ask. the most ur gettin out of that is 12 psi. it has a cut down impeller. the website stats says it can create 32 psi, in an enclosed environment, not in amotor. sorry, but u WILL have to upgrade to a d1sc. go ahead and call procharger if u dont believe me.
Old Sep 22, 2007 | 11:05 AM
mfj's Avatar
mfj
Banned
Default RE: Boost
u will never see 800 hp or 32 psi on a P1SC!! I forsee mr. detonation visiting you very shortly
Old Sep 22, 2007 | 01:05 PM
2000GT4.6's Avatar
2000GT4.6
Default RE: Boost
Your a fool running around on an unchecked 10 PSI tune from ATI. You simply must get on a dyno/ af meter to make sure the tune is ok or your just playing russian roullette.
I would never run a tune that came from ATI/Paxton/Vortech/KB or any other company that does not specialise in 2v in particular and offers a custom tune for your mods. These engines are simply too weak detonation wise... one det and your done.
The PS1C will tap out in the 4xx range.
Old Sep 22, 2007 | 01:09 PM
2000GT4.6's Avatar
2000GT4.6
Default RE: Boost
ORIGINAL: mfj
true, but he's going to need to boost at least 20 lbs for 650 rwhp
I don't agree at all... MPH has stock heads/intake cars making almost that on alot less than 20 PSI... forget itwith a H/I package....
http://www.modularpowerhouse.com/for...sterSaleen.zip
With a H/I package the car above probably would make close to 700 WHP (if notmore)at the same PSI on that novi 2000 setup.
Old Sep 22, 2007 | 02:49 PM
mfj's Avatar
mfj
Banned
Default RE: Boost
ORIGINAL: 2000GT4.6
ORIGINAL: mfj
DONT AGREE AT ALL, HUH?? well, that saleen didnt make 650 rwhp, it made 600 with 17.5 psi!! Thats close to 20 already! And with the the general concensus that for every pound of boost = 20 hp, then it would have taken 20 psi excactly to get 650rwhp, which is what i was saying!! but 20 psi is just above the efficiency range of that supercharger, meaning, that the air at being compressed to 20 psi, is very high in temperature, so it would have probably taken over 20 psi on that car to get 650 rwhp! Now im sure that u will find another lil thing to prove me wrong, but i really don't care. And since when is "17.5" a lot less 20?????? On a side note, however, that car was cammed.
Old Sep 23, 2007 | 03:36 AM
FDNYBullitt's Avatar
FDNYBullitt
Default RE: Boost
Guys, were getting away from his ?. You can run 10lb of boost at around 400 rwhp only with a VERY GOOD TUNE or it won't last very long. The bottom end of the motor, mainly pistons and rods won't hold together with anything more. Don't know if you have access to a dyno where you are but its probably the most important piece of the puzzle to do this correctly, good luck.
jwog666
Dec 27, 2021 08:09 PM
TCStangerv6
Oct 11, 2015 05:57 PM
Oct 7, 2015 07:02 PM
2015Ecoboost
Sep 17, 2015 01:48 PM
angeljoelv
SVT Forums
Sep 10, 2015 09:12 PM
