MAF Swap
Old Sep 19, 2007 | 07:21 PM
97modifiedmustangGT's Avatar
97modifiedmustangGT
Default MAF Swap
I have an aftermarket MAF cause I thought I was cool getting all these parts when I first got the stang not knowing the stock one was fine until like 350-400 HP. I think this could be a problem with my car if it is calibrated wrong because my car kind of flattens out past 3 grand. My question is can I just unscrew my old MAF and drop it in where the aftermarket one is or do I have to swap the pipe out and everything?
Old Sep 20, 2007 | 04:45 AM
contentsunderpressur's Avatar
Default RE: MAF Swap
If your new maf is bigger than the stock one which I'm sure it is then you'll probably have to just go to your local hardware store and get a couple of rubber reducers to lower the pipe size to fit the stock maf. Your right about the maf though, if the new maf is not calibrated to the size injectors you have it'll make it run bad.
Old Sep 20, 2007 | 10:05 AM
4.698GT's Avatar
4.698GT
It may not be the MAF, it may be the nature of the engine with the restrictive NPI heads on it also.
Old Sep 20, 2007 | 11:58 AM
The NPI motors are weaker than the PI motors but it's not going to just quite pulling all together at 3000 rpms either.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
jwog666
Dec 27, 2021 08:09 PM
Bokeo
Oct 10, 2015 08:28 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
guitarman376
Sep 30, 2015 05:54 PM
