spark plug black
RE: spark plug black
i just replaced the plug that was bad after driving today i will recheck tommarow and keep an eye on it... for some reason i think it has to do with a coil pack not strong enough. meaning its going bad. its only on one cylinder. so im kinda dumbfounded
ORIGINAL: Cornbread01
well i took off coil packs and checked those my primary resistance is 0 ohms and secondary is 5.8 kohms. it calls for .55ohms and 5.5 kohms do my coil packs sound like they are bad?
The plug didn't look crazy black or anything, but it may just have been fouling a tad. Keep us updated....
Ok here we go but first things to keep in mind.
1. i am gettin oil passed throught the pcv do to no oil seperator witha s/c application (on order)
2. this plug only has 400 miles on it.
3. this is only happing on one cylinder.
edit---4. im not loosing any oil(has stayed at the same level sence i changed it over 1000miles ago close to 2000 miles)
the problem came back.
know to me that black shinny stuff looks like burnt oil so im thinking blown head gasket. but then i think about the oil seperator. but then only one cylinder. help me out guys. thanks jeremy
did some more research definatly not oil but i cant figure out why 1 cylinder is doing this. either not enough spark or to much fuel... the injectors are new so im guessing coil pack i dont know
well i did a compresion test and this is my findings
on cylinders 2 and 6 there were carbon deposits
dry test
1 175 5 165
2 175 6 170
3 170 7 165
4 170 8 165
wet test
1 175 5 165
2 175 6 165
3 170 7 165
4 170 8 165
i dont think the injectors are dirty. they have only about 1500+ miles on them. i have the svt fuel pump with the same miles. all the plug except cylinder 6 have the same miles while 6 has about 300 miles. i will regap all plugs to 30 tommarow i need to buy two new plugs i dont wanna clean them i wanna a fresh look when i pull them so there is no is it better or not.
dry test
1 175 5 165
2 175 6 170
3 170 7 165
4 170 8 165
wet test
1 175 5 165
2 175 6 165
3 170 7 165
4 170 8 165
Golfsito
10-06-2015 11:02 AM
Omgitsa88Stang
10-05-2015 07:33 AM
