chevy engine swap
Old Oct 5, 2007 | 05:11 PM
tmoneymr2's Avatar
tmoneymr2
Default chevy engine swap
I am wanting to get information on how to swap a chevy small block into my 96 mustang GT with a 5-speed in it. the 4.6 that is in it is burning oil through the valve seals and now that i did a leakdown test the rings are pretty well done as well. im a big fan of ford styling but the sohc motors are just a little more expensive than a small block will be. photos from past people doing it and sites where i can get info would be very much appreciated
Old Oct 5, 2007 | 05:21 PM
amoosenamedhank's Avatar
amoosenamedhank
Default RE: chevy engine swap
If you really want a push-rod why don't you just swap the k-member with a 94-95 mustang and put a 302 in it? It would be a straight swap. You would need a new trans, eec, and wire harness but the rest should be the same.
Old Oct 5, 2007 | 05:40 PM
H0SS302's Avatar
H0SS302
dont put a chevy in a ford...... thats gay. thats said, just swap a 302 much cheaper and easier
2002GTAUTOVERT's Avatar
2002GTAUTOVERT
A Chevy powerplant on a ford chassis???
as stated above, a 5.0 will be your best bet as parts for it are dirt cheap and they can be built to make power cheap.
Old Oct 5, 2007 | 05:51 PM
tmoneymr2's Avatar
tmoneymr2
i would do the 302 swap but i already have a built 406 small block from a past cutlass project that got desroyed in the beautiful nebraska weather
Old Oct 5, 2007 | 05:52 PM
I SwearItsSlow's Avatar
I SwearItsSlow
by another cutlass for that engine then, just mho
Old Oct 5, 2007 | 05:54 PM
tmoneymr2's Avatar
tmoneymr2
but i prefer ford styling
Old Oct 5, 2007 | 06:15 PM
PistonsFan102's Avatar
PistonsFan102
Putting a chevy engine in a ford? i thought thatwas against the teachings in the bible
Old Oct 5, 2007 | 06:20 PM
tmoneymr2's Avatar
tmoneymr2
ya i know im gay im a *** nobody does that all im looking for is some information on how to do it i own a 32 coupe with a small block chevy in it and thats all i ever hear i know it can be done because racers do it all the time
Old Oct 5, 2007 | 07:02 PM
amoosenamedhank
I could really care less what you do I just wanted to let you know it would be easier to use a 5.0. If you want to use a chevy it's going to take a lot of custom work. Not something someone here is just going to be able to tell you how. Your going to need custom motor mounts, exhaust, and your going to have to do something with the trans. Not sure what though. I realize you already have a chevy engine laying around but for the money I would either go after another 4.6 or go with a 5.0.
