Idleing Problem
Old Feb 23, 2005 | 09:00 PM
Thunder Chief's Avatar
Thunder Chief
Default Idleing Problem
Seems ever since I put my flowmaster exhaust on the car takes a long time to idle back down between gears. When shifting the engine RPM's stay around 2500 and if I just coast it takes about 3 to 4 seconds to drop to my normal 750. Is my throtle sticking?..TC
Old Feb 23, 2005 | 09:26 PM
jdaniel's Avatar
jdaniel
I ♥ Acer
Default RE: Idleing Problem
Clean out your IAC and lines. Could be carbon build up.
Old Feb 23, 2005 | 09:27 PM
Dan04COBRA's Avatar
Dan04COBRA
If the IAC cleaning doesn't take care of it, next step is your TPS. (Throttle Position Sensor).
Old Feb 24, 2005 | 12:42 AM
Thunder Chief
I'm new to this, what are my IAC lines...TC
Old Feb 24, 2005 | 12:55 AM
Thunder Chief
Alright, got the IAC line definition, what do I clean them with...TC
Old Feb 24, 2005 | 01:09 AM
Higgie's Avatar
Higgie
ORIGINAL: Thunder Chief
Your not the only newbie ?? IAC line ??
Old Feb 24, 2005 | 02:22 AM
GTron's Avatar
GTron
Mine does this sometimes when I do a mod. I usually just unhook the battery cable for about 15 min and then it's fine after that. It sometimes will still hang around 1500 for a couple days or so then go back to normal. I don't know why it does it.
Old Feb 25, 2005 | 05:04 PM
Thunder Chief
Well the battery trick didn't work and my IAC lines are clean, how do I check the TPS..TC
Old Feb 25, 2005 | 05:15 PM
Derf00's Avatar
Derf00
Gentleman's Relish
ORIGINAL: GTron
Engine computer probably recalibrating itself...
Old Feb 25, 2005 | 05:17 PM
Derf00's Avatar
Derf00
Gentleman's Relish
Here's a link that should help in doing that. http://www.muscularmustangs.com/tps.php
2007CalSpec
Dec 13, 2020 11:42 AM
2007StangV6
Jan 28, 2016 06:09 PM
96stang3.8
Sep 10, 2015 06:42 AM
94stangnewbe
V6 General Discussion
Sep 7, 2015 07:39 PM
Emblazoned
Sep 3, 2015 10:45 PM
