How would you fix a loose shifter?
RE: How would you fix a loose shifter?
ORIGINAL: 5.0Sleeper
So if worse comes to worse I might end up having to buy another shifter? Where could I find that plastic "ball" to buy? Like what store?
had the same problem with my steeda. you have to tighten your bolts that hold the arm to the frame on the shifter.
i used loctite just to make sure
deff. will be buying a mgw soon. how short can you adjust that throw with those screws in the front and back of the shifter arm?
ORIGINAL: 01snake
ORIGINAL: 01snake
what is the shortest smoothest shifter?
i have a steeda short throw but its not a tri-x. does that mean its a 5.0?
and what do you mean by shifter stops?
