noise. from my car. help!
well this is the second morning in a row my car has been making a wierd noise. so this is what happens. I start my car in the morning and when i do, there is a loud noise coming from the shifter and on the right side of my car near where the headers bolt up. i checked and made sure my bolts were tight and they are. the noise goes away after about a min. or two. it sounds like when you dont have the clutch engaged and you can hear the flywheel spinning, but like 5 times as loud.
now some other notes. my dad said my clutch felt loose one day. i dont know if that could have anything to do with it. and also, i got in my car a few days ago and right when i got in i pushed the clutch in as a habbit, and i heard a pop. i pushed it in again, and i heard nothing. the car shifts fine and runs fine.
I dont know anything about transmissions or clutches, so i dont know what im lookin for.
if anyone can help please let me know.
thanks
thanks
RE: noise. from my car. help!
Try adjusting your clutch turn off the car and put it in first then press the clutch in and then pull it up until it clicks.I dont think it would be your clutch if it only does it in the morning but its worth a try.
bradleyb
11-27-2015 07:50 PM
