One wheel peel
Old Dec 4, 2007 | 10:31 PM
clix813's Avatar
clix813
Default One wheel peel
What could be the cause of this. I noticed mines starting to do it alot more lately. Its just i feel like a sixer when i turn a coner and give it a little and it just smokes this inside tire.
Old Dec 4, 2007 | 10:39 PM
03truebluegt's Avatar
03truebluegt
Default RE: One wheel peel
It could be any number of things, but a possibility is the clutches in the diff. I had to have mine looked at for making noise and the ford guy said they were common.
Old Dec 4, 2007 | 10:49 PM
Stone629's Avatar
Stone629
Bad diff clutch probably. As for the cause of this, have you been leaking gear oil?
Old Dec 4, 2007 | 10:59 PM
clix813's Avatar
clix813
not that i can tell. the bottom does have a stain of were gear oil could be leaking but dont they all have a little stain?
Old Dec 4, 2007 | 11:02 PM
Projectquick's Avatar
Projectquick
Not really. If you are losing gear oil, even a little then that could be causing extra friction in the clutch plates or even overheating the diff could be the problem.
Old Dec 4, 2007 | 11:08 PM
clix813's Avatar
clix813
how do i tell if its full or not?
Old Dec 4, 2007 | 11:17 PM
2000GT4.6's Avatar
2000GT4.6
Is it doing this in a straight line?
Old Dec 4, 2007 | 11:18 PM
uberstang1's Avatar
uberstang1
Chupacabra
stick a little pipe cleaner into the fill plug , if that pumpkin is bone dry there wont be much on it
Old Dec 4, 2007 | 11:27 PM
clix813's Avatar
clix813
well it depends some times it will do it in a straight line but thats only if there is a little bit of dirt on the road or something else that will make it loose traction easily. but it will do it almost every time i want to power slide it around a turn.
Old Dec 5, 2007 | 10:34 AM
Brute03's Avatar
Brute03
your clutches are most likey getting worn, same thing used to happen to me on right-hand turns. how many miles do you haveon your car?
if you have a lot of miles, you can buy a little time by changing the fluid and using as little friction modifier as you can to avoid binding and popping. i did this and now i spin both wheels again
jwog666
Dec 27, 2021 08:09 PM
mungodrums
Sep 28, 2015 10:54 PM
GLOCKer
Sep 28, 2015 07:36 AM
folivier
Sep 26, 2015 02:28 PM
lincolnshibuya
Sep 24, 2015 10:46 PM
