Quick QUESTION
Old Jan 7, 2008 | 06:46 PM
bullittracr's Avatar
bullittracr
Default Quick QUESTION
ok so i jus got home from work, and my tri ax shifter came in yay. but anyway i was reading the instruction as an overveiw and realized that is say this as step eight. 8. apply a thin bead of siliconegasket maker to the transmission mounting surface.
this is not supplied should it be? and if not what could i use or where could i get some?? thanx in advanceguys
Old Jan 7, 2008 | 06:52 PM
tbirdscwd's Avatar
tbirdscwd
Default RE: Quick QUESTION
Any hardware or autoparts store will have it. It comes in a tube and is like 6 bucks. Just go get some, it's always good to have some on hand.
Old Jan 7, 2008 | 07:53 PM
bullittracr
ok kool is there any specific brand that works the best.
Old Jan 7, 2008 | 08:04 PM
bullitt33's Avatar
bullitt33
PERMATEX is what i recommend
[IMG]local://upfiles/87563/82192AA40B784B0989014262026993E1.jpg[/IMG]
Old Jan 7, 2008 | 09:40 PM
arcticman37's Avatar
arcticman37
any brand will work fine
Old Jan 7, 2008 | 10:25 PM
effingroovin647's Avatar
effingroovin647
agreed just about any brand will do
Old Jan 7, 2008 | 10:35 PM
SINISTER's Avatar
SINISTER
Make sure you get the High Temp kind. I think it is usually red, but double check on the package.
Old Jan 8, 2008 | 01:27 AM
gbic1's Avatar
gbic1
Any Color is fine it dont get hot there. I like black or grey it just looks better. Now if you need some serious RTV then go to the Ford dealer and ask for a tube of the Diesel grey stuff. It is used in caulking gun and is bad A$$. Make sure before you put it on that surfaces are spotless (no grease I use brake cleen on a claen rag to wipe it off first) and it only takes a little you are not glueing an elephant.
tmdm
May 2, 2021 02:49 PM
svfetter
Oct 5, 2015 11:39 AM
treesloth
Sep 28, 2015 07:03 AM
Big Al's 03
Sep 15, 2015 09:05 AM
Mustangmalo
Sep 6, 2015 05:22 PM
