Quick Question
Old Jan 30, 2008 | 04:26 PM
Red02GT's Avatar
Red02GT
Default Quick Question
I'm sure I could find this if I search, but I don't have time.
I've got 245/45/17 on the front, I'm about to purchase 315/35/17 to put on some 17x10.5. It's ok to have 45 on the front and 35 on the back due to the different width correct?
Old Jan 30, 2008 | 04:27 PM
timeformiller44's Avatar
timeformiller44
Default RE: Quick Question
i have 45 on front and 40 on back.. havent ran into a problem.. u should be fine
245 45 17 front 275 40 17 rear
Old Jan 30, 2008 | 04:37 PM
texas_stang02's Avatar
texas_stang02
you should be fine. the 45 and 35 is the tire's aspect ratio.. for a 245/45-17, that means the tread width is 245 mm, and the sidewall is 45% the tread width (45% of 245 mm). that's why when you gowider on the tread width, you go down on the aspect ratio, otherwise you end up with a tire that's way too tall.
Old Jan 30, 2008 | 04:52 PM
timeformiller44
+1 to the 10th powerrrrr
Old Jan 31, 2008 | 07:24 AM
Eagle2000GT's Avatar
Eagle2000GT
It's the perfect combination if you are staggering your tiresbecause it will not throw off your speedometer.
245 x .45 = 110.25 height.
315 x .35 = 110.25 height.
tmdm
May 2, 2021 02:49 PM
svfetter
Oct 5, 2015 11:39 AM
treesloth
Sep 28, 2015 07:03 AM
Big Al's 03
Sep 15, 2015 09:05 AM
Mustangmalo
Sep 6, 2015 05:22 PM
