MGW vs. Pro 5.0 vs. Steeda TriAx
#21
RE: MGW vs. Pro 5.0 vs. Steeda TriAx
is the blue one that much shorter and is it difficult just to drive around town or should I just go with red.
PS you guys got me hooked on the MGW.lol mainly cause of the easier installation and no noise[sm=smiley20.gif]
#23
I wish
I have no problems driving with the blue handle. It is a litter tougher to shift (less leverage) but not difficult once it is broken in. I am 6-2 and I like it.
My shifter install write up
Here is the write up I did on installing the shifter in a '03GT and changing the fluid.
#25
Thanks
It was worth it to change the fluid. I had the TSB done on the tranny just before I put it away. I planned on putting purple in it when I changed the shifter. It is much smoother and I don't have the 1-2 grind anymore (TSB should have solved it but still seemed to do it when I put it away)
Only tacked on maybe 10mins into the whole install. Hardest part was getting the tranny plug out[:@]
#26
My Tri-Ax made some noise when I first got it, but it's going away. I don't mind it....all that matters is that you don't have a stock shifter anymore. Everyone will have their opinions.
#27
ORIGINAL: SilverGTV8
I wish
I wish
#28
I had never heard of the MGW shifter until I got on this forum, I need to get a new 1 and I think I might go with that. I have a Tri-Ax now, but I just got a 3650, so I think I might go with the MGW.
#29
ORIGINAL: dan
Nice write up. I have a question for you. Is it nessesary to jack the car if your not changing the fluid? Is the installation easy if your not changing the fluid? thanks!
I wish
I wish
#30
It makes it easier if you jack the car up to get at the bolt. I just jacked it by the K-member popped it free, removed to let drain. Put her on the ground again to get all the fluid out. Did everything up top I needed to the tranny ready to install the shifter. Picker her back up, put some thread sealent on the plug (it's a pipe plug) reinstalled, lowered back down and poured in the fluid.
Pretty easy.
Pretty easy.
ORIGINAL: dan
I wish
I wish
mungodrums
09-28-2015 10:54 PM
09-24-2015 09:18 PM
