4.6l aftermarket intakes
RE: 4.6l aftermarket intakes
Trick Flow, Professional Products, Logan Motorsports, all still make manifolds for the 4.6. Reichard racing and HPS used to make manifolds for them, but you'll have to find those used.
The Trick Flow is probably your best option unless you have some sort of outrageous setup that would require the use of a Logan or Reichard Racing. Or you could try to get your hands on the intake and accesorries from a bullitt. The trick flow is basically a Bullitt manifold on roids. It comes with everything you need for the install and it is very nice.
jwog666
12-27-2021 08:09 PM
daltron
04-28-2016 08:10 PM
bradleyb
11-27-2015 07:50 PM
09-24-2015 09:18 PM
